Transmission leaks... needs a fix
Hey guys,
Got a bit of a problem here... What do I ask for when calling to order the new seal?
Please see the following pix
fluid leaks out nicely.... I lose about a pint every few days
Thanx for your advise
TC
[IMG]local://upfiles/52242/48519424A5F144E081D6683EE750CD80.jpg[/IMG]
TC
RE: Transmission leaks... needs a fix
I believe that is called the gear selector shaft seal. It goes behind the neutral safety switch. You will need to remove the nut and the arm. Remove the switch and you MIGHT be able to replace the seal from there.IF NOT you have to remove the pan andvalve body if you cant replace the seal from the outside.
Good Luck
Good Luck
ORIGINAL: blue66mustang
Good Luck
Good Luck
theres 2 seal there 1 o ring that you can fix without pulling pan on the kickdown arm and the other is like they said you would have to pull the pan ,vavlebody and kickdown arm. mite try a little brake fluid 1st just to see if it would help softin it up some maybe a once and drive it around for awhile
