am i wrong?
Old 02-02-2008, 09:46 PM
dlynch
dlynch's Avatar
Default am i wrong?
k i striped my gas tak of all paint i used aircraft striper on it and i think i may have gotten stripper on the out side of the sending unit. im just woundering if there was a rubber seal around it that it could have posible eatin threw? sorry if i dont make any since i wish i had a picture i could show.
dlynch is offline
Old 02-02-2008, 10:06 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
Default RE: am i wrong?
yes theres a seal under the sending unit sandwiched between the gas tank
rmodel65 is offline
Old 02-02-2008, 11:50 PM
jlp66stang
jlp66stang's Avatar
If it was a old seal, it would be a good time to replace it anyway. Trust me, you don't want to fill it with gas to find out you have a leak, especially if you don't have a drain plug.
jlp66stang is offline
Old 02-02-2008, 11:52 PM
dlynch
dlynch's Avatar
can you buy the ring seperat? or would i have to buy a hole new sending unite?
dlynch is offline
Old 02-03-2008, 12:15 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
yeah you should be able to pick one up probably from auto zone or advance if not a mustang parts house will do
rmodel65 is offline
Old 02-03-2008, 01:13 AM
valley firearms
valley firearms's Avatar
I doubt the stripper would have hurt it.
valley firearms is offline
Old 02-03-2008, 02:59 PM
dlynch
dlynch's Avatar
also since its striped i like the silver metal color of it sitting in my new painted black trunk can i just do a coat of clear over the bare metal?
dlynch is offline
Old 02-03-2008, 03:16 PM
jaw66
jaw66's Avatar
Yes you can clear over the metal. I would wet sand the metal with a 2000 grit wet paper. You will need a mechanical bond or the clear will flake off. Wipe the metal clea with an enamel reducer. It dries real fast and will remove the water very fast. Once you enamel wipe it you go directly to spraying.
jaw66 is offline
Old 02-03-2008, 03:37 PM
valley firearms
The clear may flake off and make it look worse. Just wax it and keep it clean.
[align=left] [/align]
Old 02-03-2008, 06:30 PM
dlynch
dlynch's Avatar
scotch brite and wax and grease remover wont keep it from flaking off?
dlynch is offline
Dokilar
15
10-16-2015 08:13 PM
Matt's 95 Stang
10-05-2015 07:16 AM
ChampInSD
10-02-2015 04:55 AM
marc954
09-29-2015 11:18 AM
Quick Reply: am i wrong?
