65 mustang suspension set up options
Old 11-04-2008, 08:31 PM
gothand
gothand's Avatar
I don't know about your rear springs, but in my '65 fastback, I have the Global West suspension (F&R), adjustable front swaybar, subframe connectors, Koni front shocks & QA-1 rears. Whether it is a good value or is better or worse than other products, I can't say. What I can say that it does handle like it is on rails and is noticably better and more predictable than my '65 coupe was with a Grab-a-trak style setup was. Of course, for the extra money, it better be.
Good luck!
gothand is offline
Old 11-17-2008, 11:31 PM
bigbadbenw777
bigbadbenw777's Avatar
anybody have the front coilover on their 65-68 mustang? how much better is that set up compared to all the global west suspension set ups? Any reviews from people that are running coilovers would be great!!!!!!!!!!! What more can I do to improve my rear suspension? I already have 5 leaf grabatrak leafs with the racing shackles, I plan on getting rid of the rear air shocks and replacing them with the edelbrocks? or any different suggestions? Oh.....and I do have traction bars......any help or input is appreciated,
Regards....
Ben
bigbadbenw777 is offline
Old 12-10-2008, 04:25 AM
jcthorne
jcthorne's Avatar
I too am thinking of going with many of the componenets offered by opentracker to rebuild my 65GT front suspension.
On the springs, has anyone gone with the progressive rate front coils they offer?
I am doing the roller perches and an adjustable strut but are the roller UCA and LCAs really all that beneficial for a street crusier considering the stiff extra cost?
jcthorne is offline
Old 12-10-2008, 09:15 AM
chappys4life
chappys4life's Avatar
My 66 is pretty much stock excepy for the shelby drop. I want to rebuild my suspension but I am doing it in stages because of money. So far this is what I have planned.
stage 1:
Grab-A-Trak Performance Suspension Rebuild Kit
stage 2:
Grab-A-Trak 5 Leaf Mid-Eye Springs
Grab-A-Trak 620 Coil Springs w/ poly insulators
Poly Spring shackles
Edlebrock IAS shocks
stage 3:
monte carlo bar
front sway bar (not sure on size yet)
stage 4:
Open tracker Make-It-New Steering Rebuild Kit w/ rolelr idler arm
Maybe global west tubular tie rod adjusting sleeves
Things I am still debating to add to the list are:
subframe connectors, traction bars (ex shelby), and adjustable strut bars
chappys4life is offline
Old 12-10-2008, 12:10 PM
bigbadbenw777
sounds like an awesome set up
Old 12-10-2008, 01:42 PM
fakesnakes
fakesnakes's Avatar
In my 66 fastback, I have the Shelby drop, 560 lb. springs 1" drop springs, roller perches, a 1" sway bar, and a TCP R&P unit in the front. In the rear, 4.5 reverse eye springs and Koni's all around with 245/45-17s on 17X8 wheel all around. Also, an export brace, monticarlo bar, subframe connectors, and a 4 point roll bar. I should take my first drive in early January if the weather cooperates.
fakesnakes is offline
Old 12-10-2008, 02:04 PM
urban_cowboy
urban_cowboy's Avatar
Are you running Koni Classics? Are both compression and rebound adjustable or just rebound?
urban_cowboy is offline
Old 12-10-2008, 02:12 PM
Starfury
Starfury's Avatar
stage 1:
stage 2:
stage 3:
monte carlo bar
stage 4:
Not what I'd recommend. For one, most of the Grab-A-Trak suspension stuff doesn't have a rubber bushing option, which means you're stuck with squeaky polyurethane bushings that will reduce ride quality. For another, those springs are going to be STIFF, especially on a lighter '66. And finally, your 'stage 3' should be the first things you do, unless you do it all at once.
If you have worn suspension components, you need to figure out what those are so you can plan out what you need to buy. Control arms, tie rod ends, etc. Focus on steering first. If you have bad steering linkage components, they need to get replaced ASAP. Then move on to suspension. If you have bad ball joints or control arm bushings, start looking for (stock replacement) control arms and springs.
Once you fix everything that's obviously worn out, here are some parts I'd recommend:
15/16" front sway bar (poly bushings are ok here)
Export brace and monte carlo bar
*560lb 1" drop springs from OpenTracker
*Roller spring perches from DazeCars
*New rubber upper coil spring insulators
*Shelby drop (template and drill bit available from DazeCars)
4.5 leaf 1" drop spring kit (I'm happy with mine from M+)
Roller idler arm from OpenTracker (if you have a m/s car)
Traction Master traction bars (not cheapo bolt-on jobs)
Subframe connectors
Everything with a * should be done at the same time, since you're going to have the front end torn apart anyway.
This setup will give you a firm but still streetable ride that handles great. Putting ultra stiff springs on the car will make it jittery and unsafe while cornering on anything but the smoothest of roads.
Starfury is offline
inyadreems
08-21-2015 09:10 AM
krazykevin
08-18-2015 08:42 AM
robjh22
08-17-2015 07:35 AM
daytooday
08-11-2015 09:22 AM
Quick Reply: 65 mustang suspension set up options
