guages dont work!!!help
Old 01-15-2009, 04:01 PM
Dan's 66 Stang
Dan's 66 Stang's Avatar
Default guages dont work!!!help
hey. I have 66 stang 289 and I cant get my guages to work I have tried replacing the voltage regulator on the back of the instrument panel twice. Both times I did this the gauges would work for a while. But something is causing the regulator to burn out and thus my guages wont work. any ideas on what could be causing the regulator to burn up?
Dan's 66 Stang is offline
Old 01-15-2009, 04:06 PM
urban_cowboy
urban_cowboy's Avatar
It may be time to send it off to someone like this.
http://www.instrumentsrus.com/
I plan to do that at some point when I am tearing down the body and paint.
urban_cowboy is offline
Old 01-15-2009, 04:16 PM
65Coupester
65Coupester's Avatar
The gauges might be shorting on the gauge housing.
Make sure the nuts are tight that tighten the gauge screw to the housing.
You can test with an Ohm meter for a short from each screw to the housing.
65Coupester is offline
Old 01-15-2009, 08:35 PM
ThanksDad
ThanksDad's Avatar
After I replaced my dash bezel my gauges died. We tracked it to a bad voltage regulator. I replaced it and they worked a few days then died again. After going through I think 3 of them I found an electronic one. It was about twice the cost, I think $50+ plus shipping. It has been in for about a year now and the gauges are all still working.
At least they were a month ago before my damn starter died. Now nothing works since I can't start her.
ThanksDad is offline
Old 01-15-2009, 10:41 PM
chris66dad
chris66dad's Avatar
I made solid state one with 5 dollars in parts from Radio Shack.
Here is my "How To" from our website.
http://chris66dad.tripod.com/id29.html
Click on the pictures to enlarge them.
Hope it helps you out and it will take about 1 hour to build.
Better than 50 dollars for and original that will fail...
chris66dad is offline
Old 01-16-2009, 06:55 AM
ThanksDad
ThanksDad's Avatar
My brother in law said his Dad had done the Radio Shack homemade $5 unit. He said it worked great but we could not find any instructions on how to do it.
Old 01-16-2009, 08:20 AM
Norm Peterson
Norm Peterson's Avatar
Wonder if using a little heat sink compound / paste at least under the regulator would be beneficial. Supposedly available at Radio Shack is
http://www.pcguide.com/ref/cpu/char/coolCompound-c.html
Norm
Norm Peterson is offline
Old 01-16-2009, 09:13 AM
chris66dad
chris66dad's Avatar
Norm
Thanks Norm. Good catch!
I did put a little dab of the white dielectric grease on it. I forgot to add the picture showing it. I will update that today.
Ron
1TUFF302
11-05-2015 04:02 PM
Pyrate Dave
09-10-2015 07:30 PM
96stang3.8
09-10-2015 06:42 AM
JoshyGT
09-07-2015 02:04 PM
cbird1177711
09-03-2015 08:43 PM
Quick Reply: guages dont work!!!help
