Charge issue with 1 wire alternator
Its lower because of the under pulley, you should really take it off the alternator, its not going to help you any just cause you problems because its going to generate less voltage. Put the original pulley back one and you'll be ok
100, 1966, 66, alternater, alternator, alternators, amp, charge, charging, chart, ford, mustang, powermaster, rpm, switching, wire, wiring
