i was thinking bout putting one in the 65. but have no idea were and what to get to do this swap, like what late model stang do they come out of, can you get them at a junk yard etc
Any mustang that is a 5.0 and a 5 speed is a t5 the fox body and early sn95.You need a t5 cross member which most mustang auto part house sell.If the car is a auto you need the clutch pedal same thing most part houses sell them now.For a cable clutch which is the simplest way http://www.mustangsteve.com/cable.html or talk to http://www.moderndriveline.com/ he can sell you everything you need and just get the tranny from a junkyard.
There is T-5 swap info in the FAQ. I would read as much as you can in there and then come back with questions. There are a ton of T-5's out there that will not work for the conversion and identifying which is which can be tough. Modern Driveline's site is also a big help.
