SSBC Brake System
Old 04-27-2009, 07:45 PM
chewy1234
chewy1234's Avatar
Talking SSBC Brake System
I am starting the plumbing portion of my SSBC conversion. Can anyone post a pic of the dual master cylinder with using the stock distribution block. Also, after the MC is bench bled how do you connect the lines without leaking brake fluid all over the place. Thanks.
chewy1234 is offline
Old 04-27-2009, 08:52 PM
tempoffroad
tempoffroad's Avatar
after you bech bleed it the fluid for the most part will stay in me master cyl unless you push the piston in. i would put a rag under it but for the most part it will not just run out of the holes
tempoffroad is offline
Old 04-27-2009, 09:29 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
this is all i got right now
rmodel65 is offline
Old 04-27-2009, 10:34 PM
eZ
eZ's Avatar
This is the best pick i have at the moment. I bent everything myslef so sorry if it looks terrible. this whole mechanic thing is new to me
eZ is offline
Old 04-27-2009, 11:49 PM
Starfury
Starfury's Avatar
For the short lines to the distribution block, I'd strongly recommend using Napa's PolyArmor brake line. It has a teflon outer shell which allows it to bend easier without as much risk of kinking. You should still use a socket to get really tight bends, but I had no problems running mine.
Unless you have a flaring tool, buy short pieces of pre-bent line. Cut a wire hangar into pieces the same length as the lines. Bend the wires into shapes that work and won't interfere with anything, then bend the lines to match the wires. Don't be afraid to work a big U or a complete loop into the line if you've got extra. Most manufacturers actually do this at the factory to help with vibration issues.
eZ, you really should consider getting a distribution block. It really cleans up the engine bay.
Starfury is offline
Old 04-28-2009, 08:05 AM
chewy1234
chewy1234's Avatar
I got the SSBC kit and it came with 2 short pieces of tubing. I know its for the proportioning valve, just wanted to see what it should look like.
2015Ecoboost
09-17-2015 01:48 PM
09-16-2015 07:53 PM
LivingInThePast
09-16-2015 12:20 PM
09-10-2015 08:39 PM
09-08-2015 11:50 AM
Quick Reply: SSBC Brake System
