Harmonic Balancer
Old 05-04-2009, 07:13 PM
dcohen
dcohen's Avatar
Default Harmonic Balancer
So I am getting to the point where I am about ready to drop my 289 back in my 66 coupe. The engine is freshly rebuilt with performance mods (performer rpm heads, performer rpm intake, comp cams cam, etc) but it still has the factory harmonic balancer. What are yall's opinions on this? Is it something that I should just go ahead and replace or will the original be fine? Also, would a stock replacement be sufficient or should I opt for a more expensive performance balancer?
Thanks guys
dcohen is offline
Old 05-04-2009, 08:05 PM
Starfury
Starfury's Avatar
Personally, I'd replace it. Powerforce makes a decent balancer for a good price that has both 3 and 4 bolt hole patterns on it, and can be changed between 28oz and 50oz imbalance. That's what I'm running on my 331.
Starfury is offline
Old 05-04-2009, 09:15 PM
dcohen
dcohen's Avatar
what determines whether or not i should run a 28oz or a 50oz?
dcohen is offline
Old 05-04-2009, 11:40 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
289/302 upto 1981 use 28 oz balance 1982+ uses the 50oz
all 351w/c motors use 28oz
rmodel65 is offline
Old 05-05-2009, 12:56 AM
remicks
remicks's Avatar
I would swap it while you have to motor out, its just much easier. Plus its a pain in the *** when it does go bad, the vibration and things like that always seems to happen at a time when you can't replace it.
remicks is offline
mtgldr
02-03-2024 09:00 PM
jessicarabbit
09-25-2015 12:41 PM
LivingInThePast
09-16-2015 12:20 PM
09-08-2015 11:50 AM
Urambo Tauro
08-27-2015 10:53 AM
Quick Reply: Harmonic Balancer
