any one have some pictures of how they oriented their proportioning valve for disc/drum barkes? im just wondering if there are better or worse ways to go about it.
thanks
I mounted mine on the shock tower side facing the driver, with the **** pointed towards the engine. If you're talking about an adjustable valve that is.
yeah i have a an aftermarket adjustable from csrp. gotta run down and get a small section of brake line tommorow or else i would be out there bleeding brakes all night just to get to drive it this weekend. thanks for the help
If possible you should mount everything so all lines/components are downhill from the MC. That way any air in the lines will rise to and escape from the MC.
It's not necessary, but it makes bleeding and maintaining the brake system easier.
yeah, i did keep air flow in mind. I ended up with sort of a hack job, but its kinda temporary, when I look into getting a power booster for the brakes, im going to redo all the brake lines. I ended up with a bunch of spiraled brake lines haha
