Why am I losing coolant
+1 on the expansion tank. I just went thru this 3 months ago. The exp tank solved the overflow problem.
The only thing I haven't figured out, is why the exp tank never has anything in it when cool? I would expect it to have some fluid left in it.
I guess the radiator pushes out more than the tank can hold,and sucks back everything in the tank. But shouldn't the radiator level gradually decrease if that is the case, and then overheat?
I've been refilling the radiator, and exp tank periodically to prevent that. I guess I'll start waiting, and see if it settles out at a level that doesn't overheat.
Got it all fixed up. Man, you guys wanted me to buy expensive stuff and all it took was an old Corona bottle, the hose off a second hand enema bag and little duct tape.
Seriously though, thanks. You were right, it has not leaked anymore since the first time it spilled out after I topped off the radiator.
My junk yard charged my 2 bucks for an over flow container. and I picked up a free used fire extinguisher that I can use and fabricate one out of. Just drill and tap a few holes and I should be good!
Glad the problem was fixed.
