Remanufactured 390 Engine for a 67
Old 07-05-2005, 01:51 PM
67CarolinaCoupe
67CarolinaCoupe's Avatar
Default Remanufactured 390 Engine for a 67
Well, I'm looking into different engines and had a couple of questions for you guys.
#1. How do you guys feel about remanufactured engines in general?
I'm looking at www.hiperformer.com and they have several different engines and offer a 7 Year / 100,000 mile warrenty on the engine.
#2. Will a 390 engine fit into a 67 coupe without modifications?
I know that some 67's came with 390's but I'm not sure if they were coupes. I know there are a lot of things I'll need to replace as I'm running an I6 right now. I just don't want to deal with any mods to the shock towers or anything like that.
Thanks,
Bob
67CarolinaCoupe is offline
Old 07-05-2005, 02:25 PM
uwti
uwti's Avatar
Default RE: Remanufactured 390 Engine for a 67
390 engine will fit! However keep in mind of course that you need to use big block motor mounts, also if you are running headers you may need to bang up your shock towers, changing spark plugs and tightening header bolts is next to impossible, it can be done but you need serious patience.
uwti is offline
Old 07-06-2005, 10:55 AM
67CarolinaCoupe
Thanks uwti..... what do you mean when you say "bang up the shock towers"?
Anybody else have any thoughts on this?
Old 07-06-2005, 11:30 AM
uwti
uwti's Avatar
I have a 67 with a 428 engine, FE same dimensions as the 390. If running stock exhast manifolds you are fine, I ran hooker comp headers, and in order for them to fit I had to dent the shock towers on each side, I heated them, banged them up with the hammer, than repainted. It all sounds alot worse than it is! at the end of the day you really need to look hard to see what was done.
uwti is offline
Nick Oliver
10-17-2018 04:22 AM
AmericanMuscle4.6GT
11-10-2015 02:06 PM
rksnow1
09-14-2015 08:46 PM
TfcCDR
09-14-2015 12:08 PM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: Remanufactured 390 Engine for a 67
