4sd shifter knod/reverse/ removal
so i have a 66 4 speed and the boot around the shifter is torn, so i have a new one i want to install and im not sure how to get the reverse pull off? anyone kno how it comes off so i can slide the new boot on?
thanks in advance
thanks in advance
You don't. Removing the T bar destroys the handle. I have repaired many such handles, and it involves acetylene, brazing, etc. You don't want to go there.
Remove the ****, and carefully stretch the boot over the T bar one side at a time. Don't let the bar poke a hole in the boot, and use a smooth screwdriver shank to stretch the hole.
Are you planning to replace the handle attaching parts? make sure you have, or get, the unique thick hardened washers for the rubber grommets.
The 66 shifter had a lower shift boot as well as the upper. This keeps dirt and water out of the shifter, and dramatically reduces heat and noise in the car. These are available new. They were usually cut off and thrown away by the first lazy mechanic who worked on the car.
Clean the daylights out of the shifter, and lubricate it while you're in there.
ok great thanks for your help!
jwog666
12-27-2021 08:09 PM
junior04
09-28-2015 10:53 AM
