rear end gears
#21
I have a 302 small block, 4 barrel Holley, RPM air gap intake, b303 ford racing cam with 480 lift, aluminum pro comp 210cc heads, Roller rockers, holley 90psi electric fuel pump, t5 5speed trans. I was giving a 9inch ford rear end from a buddy in oklahoma and i need to rebuild it. Im not going to drive my mustang on the highway much, if at all, so i want a pretty high gear from great launches and accel. What gear should i get? Also if someone had a guess, How much HP could my motor make?
Thanks
Aaron
Thanks
Aaron
Your tire size may help you choose your rear gear ratio. For me 3.89 gears would be my limit with my current set up or a set up with a little more power. A lot more power and I would want 3.70's.
Based on your post, I would recommend 3.89's.
musnicki
09-23-2015 07:11 AM
inyadreems
08-21-2015 09:10 AM
