Vacuum Advance Problem
Old 06-29-2010, 11:26 AM
kalli
kalli's Avatar
I have no idea, but all stock measured at manifold I'd say 15+ ???
the needle in gauge should stay steady
kalli is offline
Old 06-29-2010, 11:46 AM
Stepman
Stepman's Avatar
This sounds more like a fuel problem than a vacuum leak. Does the choke open as it warms up? What are you running for a fuel pump?
Stepman is offline
Old 06-29-2010, 06:11 PM
Cogtx
Cogtx's Avatar
Originally Posted by 63Falcon
Does anyone know much vacuum should a 6 cylinder 170 with a 1100 carb produce? I think I'll put the vacuum tester on it again.
Here is a link to the vacuum discussion about the 1100 carb....17 inches of HG at idle is the short answer...
http://tffn.net/phpBB3/viewtopic.php...4934&view=next
Cogtx is offline
Old 06-29-2010, 08:03 PM
63Falcon
63Falcon's Avatar
It's an manual choke. Fuel pump is a replacement from AutoZone.
Fuel Pump
63Falcon is offline
Old 06-29-2010, 08:21 PM
63Falcon
63Falcon's Avatar
Is he testing the vacuum at the carb port? Picture
63Falcon is offline
Old 06-29-2010, 08:38 PM
Cogtx
Cogtx's Avatar
That would be the distributor vacuum tube adapter (your pic with circle around it).. he probably is testing the vacuum there...
Cogtx is offline
Old 06-30-2010, 09:33 AM
MBDiagMan
MBDiagMan's Avatar
I really think that you're off on a tangent.
Connect a vacuum gauge to any vacuum port and see if you have 17 or 18 inHg. If everything is correct, you should have at least this much.
Whether you do or whether you don't, you need to do a thorough going over. In fact it wouldn't hurt to start with a compression check just to know that you're starting the process from a solid foundation.
Does it still have points? If so, make SURE that they are spotlessly clean with no pitting and adjusted correctly, then the timing set to factory setting with vac advance disconnected and plugged if that's what it calls for.
With points in good shape, adjusted properly and timing set, adjust the idle speed close to spec, and then turn the idle mixture screw in until it stumbles then back out maybe an 1/8 or 1/4 turn.
If you have trouble accomplishing any of these steps along the way, troubleshoot the reason why and correct it. Once you can go through all these steps to a smooth, hot idle, you'll have it.
When you get to one of these steps that you cannot get correct, post it here and we can go from there.
I really believe that you have focused on your vac advance issue and it is likely not your problem at all.
MBDiagMan is offline
Old 07-06-2010, 11:41 AM
63Falcon
63Falcon's Avatar
Tested vacuum. It had around 16 off the manifold. Probably ok there. Compression was pretty good: 135, 140, 150, 150, 155, 150. New points, condenser, rotor, coil. Gap good. Timing good. New plugs and wires.
Got the car to not die when putting in reverse and at operating temperature. Closed choke about 10°. Has anyone experienced this with a carb? I thought that it would run best when opened all the way at operating temp.
63Falcon is offline
Old 07-06-2010, 04:40 PM
63Falcon
63Falcon's Avatar
63Falcon is offline
Old 07-07-2010, 12:34 PM
Stepman
Stepman's Avatar
Sounds like you need to adjust the idle mixture now. Also, don't know if I missed it but, did you set the dwell on the points?
Stepman is offline
Quick Reply: Vacuum Advance Problem
