Advice needed on 67 Mustang
Old 04-03-2011, 08:09 PM
  #111
hightower2011
hightower2011's Avatar
Marc, I've got my 351w oil pan down at the barn, I'll see if that little rubber seal is still in it tomorrow, otherwise I'm just as lost as you are as far as what way to put it in!
And MustangFTW I'll keep that in mind, haha
hightower2011 is offline
Old 04-03-2011, 09:40 PM
  #112
1slow67
ROTM Moderator
1slow67's Avatar
If I get up early enough I can check on that gasket. I've got my block in the garage and my pan is in the attic.
1slow67 is offline
Old 04-04-2011, 08:27 AM
  #113
1slow67
ROTM Moderator
1slow67's Avatar
Well I just tested mine and it seemed to actually be on the hump, not on the flat sides around it. But I could have positioned it wrong since I'm getting ready for school and didn't really have time to sit down and mess with it.
1slow67 is offline
Old 04-05-2011, 10:20 AM
  #114
Novice-Owner-Marc
Novice-Owner-Marc's Avatar
OK I messed up my 4 piece seal that I first bought. So I picked up a new 1 piece rubber seal. So I need some help.
If I line up the holes I get this picture:
So do I line it up on 1-2-3, please advise:
I appreciate all help that people are able to give me.
Thanks
Novice-Owner-Marc is offline
Old 04-05-2011, 11:18 AM
  #115
MustangFTW
Guest
Posts: n/a
by the width of the gasket i say it goes on 1, just make sure the holes line up. theres like 18 holes right? there really shouldnt be more then one way to put it on.
Old 04-05-2011, 12:19 PM
  #116
OCHOHILL
OCHOHILL's Avatar
Look at the timing cover and rear main cap. Note the gooves in each and the spot for the seal tabs. There is only 1 place to put it unless you are a square peg in a round hole kinda guy.
Please don't be offended by this. Is your oil pump pickup screen on the oil pump. Is it the right pickup for the pan? Is your pan clean?
OCHOHILL is offline
Old 04-05-2011, 12:49 PM
  #117
Norm Peterson
Norm Peterson's Avatar
Will the screen be the right distance away from the pan and will it stay that way?
Norm
Norm Peterson is offline
Old 04-05-2011, 03:40 PM
  #118
OCHOHILL
OCHOHILL's Avatar
Norm
Baby steps, Norm, baby steps.
OCHOHILL is offline
Old 04-05-2011, 08:17 PM
  #119
Novice-Owner-Marc
So I jack the engine up...... put jack stands under the engine mounts..... go to put the oil pan in.... and BAM!!! Run into two lugnuts.
Here's a picture:
HELP!! Please tell me there is an easy way to get this oil pan in. I have NEVER had this much trouble with an oil pan installation before.
Thanks.
Old 04-05-2011, 08:40 PM
  #120
MustangFTW
Guest
Posts: n/a
try putting the part in the picture in before the other end. its like the battery cover on a TV remote probably need to slide one end in first before the other.
Quick Reply: Advice needed on 67 Mustang
