Aluminum Radiator
Aluminum Radiator
I have a 67 289. I have a sotck radiator, the previous owner had it recored. Under my ownership it started to leak out from the top and i had it welded. It is leaking again, Im not sure if I should have it welded again, buy another stock radiator or just get an aluminum. I told my dad about the aluminum and he says its not worth it cuz u get cant weld those. Im not sure if hes right or wrong but I cant drve with a faulty cooling system in miami. Thanks.
RE: Aluminum Radiator
The aluminums cost more but are supposed to be worth it. I'm pretty sure they are of welded construction also.
It sounds like you have a pressure problem...is your cap working correctly?
Try some water wetter next time...
Aluminum radiators definintely cool better than copper/brass core rads, but only in extreme heating concidtions such as racing. It sounds like your old rad is on it's last foot, and you need to replace it with a new 3 or 4 row. Water Wetter is a good additive, but that is only one of the things you need to do/add to get your temp to operate correctly. If your rad is leaking, then it is not holding pressure, which is what you need. Welding and re-coring radiators only makes them last a little while longer. If you truly want your Mustang to run for a long time with a good cooling system, then don't take the southern engineering way out. Get a new radiator.
