Found rust in the floor pans!
#51
Wouldn't creating a patch piece under the main panel be a better solution? I would think it would look better without the seams and also, not having to cut the main panel would provide better support. I know forming the piece would be hard but I would think a better overall solution. But, I am new to all this so maybe I am just looking at it another way, maybe the wrong way.
At least that's what I take from the picture the OP provided.
#52
Well hmm..? The drawing he made, with the blue square would work too. I think. But if I understand you right, you suggest a patch added to the underside without removing any metal from the inside existing floor? I don't like that because it would create a hollow pocket. A double walled area just waiting to rust.
If he does it either as I suggested or as the blue square drawing, and butt welds it in. There would be no visable seam. Only the weld seam, which if done half decent, won't be noticable after paint etc. Also, if you make a patch under the floor your going to be doing some shaping. With the other two options your just bending the metal down, no shaping at all.
#53
I know this isn' the best way to go about this, but it definitely was the quickest and easiest. I basically hammered that area from multiple angles until it made a connection to the rail. Then I plug welded it and then a little more from the back side.
but the floor is done for the most part
Question. The original pan had these 2 hooks in the rear bench seat area. I can't remember if this is necessary to install the seats because my new floor doesn't have this
#55
hmm...Wish I could of come over there for about an hour or so. I think that could of been stretched, layed flat and the floor look factory. I just couldn't explain it good enough. But, what's done is done. And what you did there will work just fine.
Keep the updates coming. It's progressing nicely.
Funny how similar issues come up again and again.
#56
Thanks bent metal, for now this online help will have to do
Does anyone know what those 2 hooks are called? I couldn't find reference of it in my shop manual. I'm guessing I can cut those off the original and reuse it?
KingRando
10-02-2015 08:06 AM
