Crank to Cam line up
Old 02-09-2011, 11:47 PM
ColtonS3290
ColtonS3290's Avatar
Default Crank to Cam line up
i was about to install my cam in my 1969 351w, but i forgot it need to be lined up with the crank so the timing is right, can anyone tell me how to line them up right so i dont have to tear it down again to fix it later?
ColtonS3290 is offline
Old 02-10-2011, 03:03 AM
kalli
kalli's Avatar
there's the way that most people take called "straight up". means you have the dot on the crank gear that pulls chain pointing straight "up" and the one on cam straight down, so the dots are as close to each other as possible.
This will work, however what you _should_ do is get a cam timing wheel, a dial indicator and a piston stop. This is the only way to get it 100% accurate. the straight up method might cause the cam to be about 5 degrees out (that should be worst case).
kalli is offline
Old 02-10-2011, 05:25 AM
2+2GT
2+2GT's Avatar
The woodruff key on the crank will be pointing straight up when the gearset dots are aligned.
2+2GT is offline
TCStangerv6
10-11-2015 05:57 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
svfetter
10-05-2015 11:39 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
Quick Reply: Crank to Cam line up
