versailes 9" questions
Old 05-17-2011, 03:55 AM
66 tang
66 tang's Avatar
Default versailes 9" questions
what is a "versailes" 9" rear end, obviously its a 9" rear end but what is the advantage of it? i noticed its used quite a bit, is it possible it would fit in a 66 coupe? is it out of a lincoln or some other land yacht of the 70s? i already blew the spider gears out of my 8" once and luckily scored another third member for $100, but i dont know how long this one is going to last, that and im tired of having a one wheel wonder, im more than likely going to buy a moser 3rd member with 3:50 gears and a tru track, but just wanted to get some facts before i dive in
66 tang is offline
Old 05-17-2011, 06:12 AM
Rat fink
Rat fink's Avatar
The versailes has disk brakes in the rear. If you put disks on any 9 inch set up you have the same thing. A custom made 9 inch is the only way you can get a 9 inch for a 66. If you had a 67-70 a 9 inch from a 57-59 big ford will bolt right in, Those are getting tough to find. 67-70 also came with 9 inch (some) If you want a 9 inch in a mustang 65-66 it's going to be a custom built one. Up to about 1500 HP the 8.8 is just as good as the 9 inch.
Rat fink is offline
Old 05-17-2011, 06:30 AM
andrewmp6
andrewmp6's Avatar
The versailies 9 inch is kinda a mutt you can't put any other brakes on it.I would rather just order a housing and axles you know its all new and will fit perfect not close enough.I have a currie 9 in mine 35 spline its taken 2 seasons of bracket drag racing with 600 foot pounds plus the spray.
andrewmp6 is offline
Old 05-17-2011, 08:34 AM
mr_velocity
mr_velocity's Avatar
The po claims this to be a Versallies rear but measuring it out tells me either it's not or it was cut since it measures in at 57.25" not the 58.5" of the versallies. It did have the original disk brakes on it (since upgraded) and it does have a trak-loc 3rd member but no tags of any sort.
mr_velocity is offline
Old 05-17-2011, 09:24 AM
Rat fink
Rat fink's Avatar
Andrew
Can't is a mighty big word.
I knew a guy that put a Allison 12 cylinder in a dodge dart.
I put a 460 in a Mustang ll. We landed men on the moon in the 60s.
I remember when "experts" said we can't run a quarter mile any faster than 8 seconds. Now they are in the 3s at 330 mph.
Can't put any other brakes on the rear end, Yea right
Rat fink is offline
Old 05-17-2011, 01:07 PM
dodgestang
dodgestang's Avatar
I don't think that is entirely true. I have SSBC rear disc on my Versailles in my 68 Fastback. granted I don't know if they changed the ends or not...but I have em on there
There are a few benefits to this 9 inch
1. It used to be the way to get rear disc....not needed anymore.
2. The housing has additional ribbing so it is 'stronger' than say a 57 Ford housing
3. It is a slightly wider than a stock 65 housing but close enough that the same offsets work.
4. When you put it in the 67/8 it is narrower than the stock housing, so you can run rims with much deeper 'dish' to them (which is what I like)
5. Since they came out of heavy lincolns they also tend (if complete) to have lower rear gear and trak locks in stock form
dodgestang is offline
Old 05-17-2011, 01:36 PM
tx65coupe
tx65coupe's Avatar
I have a Versailles rear in my 65. Its just ever so slightly wider. I'm running 3.50 traction lock in mine with a T5 and think its just about perfect.
The Lincoln Versailles was made from 77-80. GVM means Granada, Versailles, Monarch.
All the Versailles gear ratios were lousy. Some were 2.73 but could have been as bad as 2.52 or something like that.
tx65coupe is offline
Old 05-17-2011, 03:55 PM
dodgestang
dodgestang's Avatar
I stand corrected. I thought they were all 3.25 or 3.5s (maybe its just most of the ones I've ever looked at where already mod)
Old 05-23-2011, 04:42 AM
tx65coupe
tx65coupe's Avatar
I'm fairly certain that they were all like this and have never seen or heard of one with good gears. The best avialable ratio was 3.0:1. Here is some more Versailles tech.
http://www.mustangsplus.com/tech/versaill/index.htm
Old 05-27-2011, 09:29 PM
htwheelz67
htwheelz67's Avatar
you can install many systems on the versailles, I have installed cobra rear discs on mine, mustang steve, currie and a few others have the kit to do it.
htwheelz67 is offline
Dokilar
15
10-16-2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: versailes 9" questions
