Undercarriage paint question
Old 06-09-2011, 06:56 AM
dmaclaren
dmaclaren's Avatar
Default Undercarriage paint question
I have some surface rust that I need to remove. It's on the steering linkage, some frame or supports that will need to be wire wheel.
So, it's flat black and I want it to stay flat black. I don't have a sprayer or really want to buy one at this point.
So, I assume I need to use a primer and paint. What automotive spray can paint would I use? can I get it at an auto store or do I need to buy online?
After I wire, can I just clean with cloth or do I need a chemical cleaning, if so, what?
Thanks,
Don
dmaclaren is offline
Old 06-09-2011, 08:52 AM
Stainless Works
Former Sponsor
Stainless Works's Avatar
Any products from the POR15 or Eastwood brands offer a number of items for this job your planning. Each will offer primer, cleaners and prep materials. If you want to save a few dollars, automotive grade degreaser and some brake cleaner along with good Dupont primer and paint will work very well.
Post some before and after pictures and let us know what you used.
Stainless Works is offline
Old 06-09-2011, 09:41 AM
JMD
JMD's Avatar
Or... just go to NAPA and buy a can of flat black paint. I like the NAPA brand of flat black, dries quick and looks good.
Wire brush, clean, and spray.
DON'T us primer on these kind of parts, Primer will only serve to thicken the film, you don't want that here.
JMD is offline
Old 06-09-2011, 12:31 PM
HGC
HGC's Avatar
I used Rustoleum satin black. I think the can code is 7777. I did prime, also with Rustoleum.
Brake cleaner is toxic. Be careful. Some time back there was report posted here about a guy who used it to clean an area he was going to weld. When the welder hit a drop of the cleaner it made a brief puff of extremely poison smoke which almost killed the guy. He went into seizures. He was left with permanent injuries.
HGC is offline
Old 06-09-2011, 04:27 PM
KMatch
KMatch's Avatar
True about brake clean. It's good stuff and normally nothing to be concerned about at that level even though care should always be used, but not so when welding. Argon, brake clean, and an arc = phosgene gas. They make poison.
Another case was a guy I worked with. He'd sprayed a bunch of brake clean into the drain plug hole of an oil pan still on the car - the reason escapes me. Some time later a torch was used in the area and he made a trip to the hospital.
Back to painting steering linkage - primer is normally a good thing, but like mentioned, it's rarely used in this capacity. The metal of steering linkage is porous enough most paint will take a good bite. Even rustoleum has a chance here...
KMatch is offline
tmdm
05-02-2021 02:49 PM
guitarman376
10-11-2015 01:47 AM
Ipaman
09-22-2015 07:01 AM
mustangchef
09-04-2015 08:08 PM
raleigh05GTO
09-04-2015 07:09 AM
Quick Reply: Undercarriage paint question
