clutch pedal hydraulic
Old 06-22-2011, 08:05 PM
05gtgreen
05gtgreen's Avatar
Default clutch pedal hydraulic
Anyone use the 67 scott drake clutch pedal and the day scovel's hydraulic setup? Just wondering if I am going to have to drill a hole in the clutch pedal? Thanks.
05gtgreen is offline
Old 06-22-2011, 08:09 PM
Gun Jam
Moderator
Gun Jam's Avatar
I use Day's setup its awesome but I run the mustang Steve clutch pedal on the bearing supported bracket which is also awesome..and I have a 66 so I think im probably just wasting time as I gather the pedal assembly is not identical...I dont know.
Gun Jam is offline
Old 06-26-2011, 10:17 AM
05gtgreen
05gtgreen's Avatar
Anyone else? I am running a scott drake clutch pedal, car was originally a automatic. Also, if someone could point me to a good thread for installing one of these hydraulic kits. Where to drill holes in the dash etc, I would appreciate it, thanks!
Old 06-27-2011, 09:48 AM
chris66dad
chris66dad's Avatar
Here is JamesW detailed install information:
http://midnightdsigns.com/Mustang/HYD%20Clutch.htm
Here are some pics of my 66 install and has a picture of the new hole I had to drill:
http://chris66dad.tripod.com/id32.html
Here is a unique way to get a Hydraulic clutch to work with power brakes:
http://www.dabbles-n-doodads.com/Mustang/clutch.html
You will need to determine where the rod needs to be attached after the master has been installed. The main thing is you want it level and not binding. My original hole was to high so I had to drill a new one.
Good Luck and Be Safe
Ron
chris66dad is offline
Old 06-27-2011, 10:39 AM
05gtgreen
05gtgreen's Avatar
Everyone keeps talking about the original hole, but my car does not have one. The closest thing I can find is a covered circle (1-1/2" diameter) but its a couple inches left of the brake booster. I am running manual brakes on the car. Thanks.
Thunderball
15
11-22-2015 11:49 PM
junior04
09-28-2015 10:53 AM
MacSerio
09-27-2015 01:05 PM
ThatJuanStang
09-25-2015 08:01 AM
ccdguy
09-19-2015 05:20 PM
Quick Reply: clutch pedal hydraulic
