installing check balls in a c4
Old 10-31-2011, 06:59 PM
jojobanks
jojobanks's Avatar
Default installing check ***** in a c4
Can anyone show me a picture or a diagram of where exactly to install the check ***** in the valve body of a c4? The trans was built in 74 and has no valve body modifications.
Got my valve body out and when I opened it up 2 of the check ***** fell out. I'm not 100% on where they go.
jojobanks is offline
Old 11-01-2011, 12:19 PM
palerider
palerider's Avatar
Had same problem when I did mine - I don't have the diagrams anymore but found some instructions on the web for shift kits that show where the ***** go.
palerider is offline
Old 11-01-2011, 01:26 PM
scottybaccus
scottybaccus's Avatar
Go find the Trans-Go website. They usually have instructions for their kits available online. You'll get great pictures there.
You can also look for the wear mark on the separator plate from the ball working the edge of the hole.
scottybaccus is offline
Old 11-01-2011, 03:50 PM
jojobanks
jojobanks's Avatar
thx for the help!! that trans-go manual did the trick.
Here's a link for future reference:
http://transgoonline.com/C4ID.pdf
Old 11-01-2011, 04:17 PM
groho
groho's Avatar
I don't need no stinkin *****.....my wife threw mine out years ago....
groho is offline
Old 11-01-2011, 05:32 PM
jojobanks
jojobanks's Avatar
better get some more. you won't run right without them...
Old 11-04-2011, 07:45 AM
hotrod351
hotrod351's Avatar
i learned one thing about the check *****, make sure there not to worn down. thats what happened to my c4. there plastic, believe chevy are steel, anyway plastic wont wear down the passages. they showed me the worn down one in my tranny.
hotrod351 is offline
Old 11-04-2011, 11:43 AM
jojobanks
jojobanks's Avatar
new ones came with the rebuild kit. So my ***** are not worn down
djbigskrilla
09-20-2022 01:04 AM
JonnyBlazeGT
11-03-2015 01:10 AM
unit91
08-31-2015 10:27 AM
jjwinel78
08-17-2015 03:34 PM
'stangdude
08-12-2015 01:27 PM
Quick Reply: installing check balls in a c4
