T% speedo gear
Old 12-10-2011, 09:49 AM
MonsterBilly
MonsterBilly's Avatar
Default T% speedo gear
I am running a t5 and i never installed the correct speedo gear. I have to install a new flywheel so i am going to take out the trans.
Is it tough to install the gear and what gear do i need. I have 3.73 gears and 25 in tall tires.
MonsterBilly is offline
Old 12-10-2011, 09:58 AM
MonsterBilly
also, i previously had a 3 speed. I have it hooked up now and the speedo does not work at all. I dont know if it ever worked because the car was not drivable when i started the project.
Old 12-10-2011, 10:48 AM
Gun Jam
Moderator
Gun Jam's Avatar
No removing the drive gear simply calls for removal of the tailshaft and sliding the gear off.
You'll want to install a black 6 tooth drive gear back on that tailshaft and you'll probably want to use an 18 tooth driven gear on the end of speedo cable.
-Gun
Gun Jam is offline
Old 12-10-2011, 10:49 AM
frdnut
frdnut's Avatar
Which gear are you replacing?..If its just the speedo gear on the cable it takes about five minutes at the most.There is just a clip that you remove with a small screwdriver and swap the gear..No need to remove trans...While you have the cable out of the trans get someone to sit in the car and watch the speedo..You can give it a quick spin with your fingers or a drill to see if the speedo works.....One thing to be careful of is which side of the trans the cable goes into...The gears are cut differently..The 3 speed cable goes in on the opposite side compared to a 4 speed..I believe the T5 uses the same gear as the 4 speed so that could be your trouble if you are using an original 3 speed gear....When you pull the gear out it will likely be chewed up a bit if that is the problem...
frdnut is offline
Old 12-10-2011, 10:51 AM
MonsterBilly
Well have been reading previous threads. It seams that the t5,autos, and 3 speeds all have the same driven gear.
Only the 4 speed is the oposite rotation.
Old 12-10-2011, 03:15 PM
Gun Jam
Moderator
Gun Jam's Avatar
if you dont use the black gear on the t5 tail shaft you'll have to run a high tooth count driven gear on the speedo and those dont last long because of the thin teeth.
Gun Jam is offline
Old 12-10-2011, 03:16 PM
Coupe
Coupe's Avatar
FWIW I have a Z spec and when I tried the biggest drivin gear the ratio was right, but it ate it in a day. So now this spring when I put the trans back in I will change out the drive gear the way Gun Jam mentioned.
I have 3:55 gears.
Coupe is offline
Old 12-10-2011, 03:21 PM
Gun Jam
Moderator
Gun Jam's Avatar
ohh also FWIW...I found that some of the driven gears that fit on the speedo cable have a long end on them like a round dowel. This dowel is so long that it actually bottoms out just about the same time the screw on speedo cable retaining bracket bottoms out. The result is the driven gear getting jammed up inside the case because of the dowel on the gear hitting the inside of the t5. The results is instant failure of the driven gear and possible damage to the drive gear. Make sure the new speedo gear has a dowel the same length as the old one.
-Gun
Gun Jam is offline
Old 12-10-2011, 03:40 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
you need to know what year your t5 is from... http://www.latemodelrestoration.com/...lication-Guide
here is the 1983-1989 t5 gear for 3.73s http://www.latemodelrestoration.com/item/LRS-17271C-K
this is 1990+ its for 355's if you want a 373 gear youre supposed to put in a drive gear and a a different speedo gear
http://www.latemodelrestoration.com/...-Gear-Kit-Auto
rmodel65 is offline
Old 12-10-2011, 06:04 PM
JMD
JMD's Avatar
http://home.mchsi.com/~jroal/drive.htm
SPEEDOMETER CALCULATOR
JMD is offline
Thunderball
15
11-22-2015 11:49 PM
Bokeo
10-10-2015 08:28 PM
KingRando
10-02-2015 08:06 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Quick Reply: T% speedo gear
