Oil Pan Bolts
Old 01-25-2012, 09:06 PM
tx65coupe
tx65coupe's Avatar
Originally Posted by JMD
lol, while that is true, I LIKE nice 12 point stainless bolts on some of my engines.
For my engine bolts, it usually means wire brushing or some time in the blast cabinet to clean up and paint, or new bolts.
For those who haven't done it, cleaning and painting 1,000 oil pan bolts takes some time, new bolts go in real fast..... It is a time vs. $ thing, and since time = $.... well you get it right....
I probably don't really need the stainless ones, just usually prefer them. I won't be using the bolts that are in there. They are not the correct bolts anyway.
tx65coupe is offline
Old 01-25-2012, 09:08 PM
tx65coupe
tx65coupe's Avatar
Originally Posted by jlg2002
You need some kind of locking mechanism on those new bolts also (or you'll be cursing the amount of oil leaks you will soon have). You can get SS split lock washers at he HW store- it's money well spent. Or in the aerospace industry we use what are called "Belville washers" which are flat washers that are cupped to compress when tightened which maintains torque on the screw/bolt as another option for you think about.
I definitely agree about having some type of locking mechanism. I've never heard of belville washers, but I have seen washers shaped like that before.
Old 01-27-2012, 03:17 PM
mr_velocity
mr_velocity's Avatar
www.totallystainless.com will have every bolt you'll ever need and in many instances with the proper heads on them. Their grade 8 stainless bolts are for the most part ARP.
mr_velocity is offline
Old 01-27-2012, 11:11 PM
tx65coupe
tx65coupe's Avatar
I'll check them out.
baddog671
07-26-2016 01:20 PM
b8checker
10-08-2015 12:55 PM
UrS4
10-03-2015 06:23 AM
b8checker
09-30-2015 07:11 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: Oil Pan Bolts
