spindles
Old Jan 19, 2012 | 03:43 PM
TexasDan's Avatar
TexasDan
Default spindles
I have a 67 GTA with front disc. I want to upgrade to 13" rotors. I know that the 70 -73 spinles with fit if you drill out the ball joint socket a little.
My question is will 90 model spindles work?
I already have the calipers, and hoses that I want to use. So I dont want to buy a kit to do it.
Old Jan 19, 2012 | 04:51 PM
chockostang's Avatar
chockostang
The 67 Disc brakes are 11 19/64" in diameter--11 1/4" in reallity.
You want to go to 13" rotors-Why? The gain of 1 3/4" is not necessary for street driven car. A Full Road race machine, a different story.
Next, you do not have to do a thing to the ball joints, or spindles to put 70-73 Mustang Disc brakes on ANY 65-73 Mustang, all are same taper.
90 Model Brakes are a waste on the Vintage Mustangs. They were better Factory/Stock.
Dan @ Chockostang
Old Jan 19, 2012 | 05:48 PM
oxfordbp's Avatar
oxfordbp
Dan @ Chockostang
Hey Dan,
If he uses the 70-73 spindles wont he have to use the 70-73 outer tie rod?
Old Jan 20, 2012 | 01:04 AM
andrewmp6's Avatar
andrewmp6
Yes the tie rod end has the match the spindle year,Being a 67 i would do the factory 4 piston disc it will out stop the 2 piston cobra brakes.
Old Jan 20, 2012 | 01:11 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
check out www.mustangsteve.com he has a kit to use the late model 13 inch brakes on the classic spindles
Old Jan 20, 2012 | 06:19 AM
chockostang
Originally Posted by oxfordbp
Hey Dan,
Yes on the Tie Rods, use the 70 Mustang OUTERS, but on the Ball Joints, you don't have to do a thing, drop them on.
Dan @ Chockostang
Old Jan 27, 2012 | 11:28 AM
TexasDan's Avatar
TexasDan
thanks guys.
I'm going a different route now. I'm still putting 13" rotors on but with Wilwood 4 piston calipers. I'm going to have to make my own brackets which are not a problem. My company owns a machine shop, comes in real handly at times.
does anyone have the drawings or dimensions of the spindle bolt hole locations so I can make the bracket. I would like to go ahead and make the bracket before I start taking it apart.
Old Jan 28, 2012 | 12:38 AM
andrewmp6's Avatar
andrewmp6
Why make a bracket when wilwood makes a kit for it now?
winner99
Sep 30, 2015 07:04 PM
KillSwitchNY
Jan 10, 2006 12:38 PM
CrdStang
Sep 19, 2005 01:02 AM
67CarolinaCoupe
Sep 13, 2005 07:22 PM
eZ
Jul 13, 2005 12:53 AM
