Intake question
Old 02-11-2012, 12:29 AM
oxfordbp
oxfordbp's Avatar
Default Intake question
Besides the Performer intake what would be a good match for the Edelbrock 1406 (600cfm) carb?
Stock 289 with a 2barrel, wanting to upgrade to the 4barrel!
THX
oxfordbp is offline
Old 02-11-2012, 06:04 AM
2+2GT
2+2GT's Avatar
The Performer RPM is superior to the Performer. If you prefer original period stuff, the Cobra is almost as good as the RPM.
2+2GT is offline
Old 02-11-2012, 12:31 PM
oxfordbp
oxfordbp's Avatar
You would use an RPM on a stock motor?
oxfordbp is offline
Old 02-11-2012, 04:32 PM
Starfury
Starfury's Avatar
I'd run a regular Performer, or maybe a Weiand Action Plus.
Starfury is offline
Old 02-11-2012, 11:00 PM
oxfordbp
oxfordbp's Avatar
I was thinking a regular performer just due to the fact that Im all stock.
oxfordbp is offline
Old 02-12-2012, 07:20 AM
2+2GT
2+2GT's Avatar
OK, then, bear in mind the regular Performer is almost exactly the same performance as a stock cast-iron manifold. Not that there's anything wrong with that, my 289 High Performance engine is now wearing it's original iron manifold, and it's pretty stout.
2+2GT is offline
Old 02-12-2012, 08:48 AM
fishkg
fishkg's Avatar
We did the same on our 302.
We've been happy with the Weiand 8124 and a 1405.
fishkg is offline
Old 02-12-2012, 12:40 PM
Starfury
Starfury's Avatar
I don't know about that. I had a Performer 289 for a while and compared it to a stock 4 barrel manifold. The plenum is taller and the runners aren't quite the same. It also doesn't weigh 50lbs:P I wouldn't expect to see any significant difference in the butt-o-meter between the two, but I definitely wouldn't go out and buy a cast iron 4V manifold, even if only for the weight savings.
The RPM manifold is designed for 1500-6500 rpm use. The standard Performer intake is designed for use from off-idle to 5500rpm, where I'd expect a stock engine to be more comfortable.
Starfury is offline
Old 02-12-2012, 02:38 PM
oxfordbp
oxfordbp's Avatar
Yes I do understand the difference in power band between the two. I am thinking performer only cause it is stock!
I will eventually be building a 351...hopefully!
oxfordbp is offline
Old 02-12-2012, 02:49 PM
oxfordbp
oxfordbp's Avatar
I will look into the weiand intakes thanks.
Did you feel a big difference?
oxfordbp is offline
Quick Reply: Intake question
