What's the deal with power steering pumps?
Old 03-13-2012, 06:41 AM
scootchu
scootchu's Avatar
Default What's the deal with power steering pumps?
The power steering pump is not original on my 66, surprise. The pump that's on my 302 has a downward return and a center pressure fitting. It is attached to a 67-68 bracket. It all works, but now a leak that was small has become large. I am going to remove it and take a look, but if I have to replace it what do I replace it with?
I notice the 66's I have seen have a downward return fitting, but they also have a stud sticking out of the back. 67's have a return that faces up. What a PITA.
I also noticed while out for a short ride that the level was low, the pump started to buzz, and it seemed to affect the whole engine. I think the pump is on the way out. How stiff should the pulley rotate? Seems tight.
scootchu is offline
Old 03-13-2012, 12:16 PM
2+2GT
2+2GT's Avatar
65-66 requires a stud on the back, to brace the pump when using the correct bracket. The bracket to the rear on 67-69 was a separate piece.
If the pump, with belt removed, is hard to turn by hand it's trashed.
This is the 65-66 Ford/Thompson pump. Note the stud, and the return that goes down and out. The 67-69 used totally different hose routing.
2+2GT is offline
Old 03-13-2012, 05:36 PM
chockostang
chockostang's Avatar
As far as the turning the pump with pulley off, a good pump will still have a drag/lpoe in the turning. This is due to the orbit of the shoes rotating in the obit of the cam pack, a turning with drag.
Yes, different than the smooth turning of a late model pump that has non cam pack designs, different that vain pumps which turn easy, smooth.
Dan @ Chockostang
chockostang is offline
Old 03-14-2012, 05:45 AM
scootchu
scootchu's Avatar
Thanks guys, I appreciate the info. The current pump is dead. It is so noisy and hardly works. I may have a line on a correct bracket and pump. Hopefully I can get the right setup on this engine.
scootchu is offline
Old 03-14-2012, 08:57 AM
jp1967stang
jp1967stang's Avatar
when i was looking not to long ago before i went to manual steering the pumps themselves were not very expensive through autozone think it was $100 or cheaper.
jp1967stang is offline
Old 03-14-2012, 09:45 AM
scootchu
scootchu's Avatar
The pumps aren't so bad, although I heard many a complaint about new ones leaking, its the brackets for a 66 that are expensive. I have also read of some fitment issues on the repops. I don't want to buy a repop for 160 only to find it's off.
What did your switch to manual entail?
scootchu is offline
Old 03-14-2012, 12:25 PM
jp1967stang
New drag link, and driver side inner and outer tie rod and tie rod adjusting sleeve. About $125 or so in parts and a alinement, so like $200 or so total. I got tired or my pump going out sucked because i just rebuilt everything, mine just aways had something go wrong with it. Also my car was slammed and would rip the studs out for the header drop bracket, so i welded it and it started to put cracks in the frame rail. So i had enough of it.
I just got rid of 2 powersteering brakcets for cheap. New ones from cj pony are only $150.
Old 03-14-2012, 12:27 PM
jp1967stang
I also seen these ones for 280 if your going to buy an new bracket and pump, might be better to go with this one for the same price. I never used on but had a buddy that put one on he said he likes it. http://www.cjponyparts.com/borgeson-...-1970/p/PSPK2/
Old 03-14-2012, 01:30 PM
scootchu
scootchu's Avatar
Ah yes I saw that, but that pump needs the power steering gear box. The whole upgrade kit with hoses and such is close to $1K.
scootchu is offline
Old 03-14-2012, 01:37 PM
jp1967stang
ohh wow never knew that he never told me he did all that i though it was just a pump you could add.
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
1TUFF302
11-05-2015 04:02 PM
9550
10-26-2015 05:01 PM
raleigh05GTO
09-04-2015 07:09 AM
Quick Reply: What's the deal with power steering pumps?
