fuel line questions
Old 05-06-2012, 10:59 AM
torinostroker
torinostroker's Avatar
Default fuel line questions
so i am running fuel lines but a friend of mine is not running return lines he has the same motor. a 302 with a carburetor. has anybody done this? if so how much psi you run with a electric pump or did you use the mechanical. and is it to rich to run the mechanical with no return?
torinostroker
torinostroker is offline
Old 05-06-2012, 12:05 PM
Iskwezm
Iskwezm's Avatar
most street pumps are about 5-7 psi which a carb will only need max 7 psi or it will ift the needle from the seat..If its a "race" type pump, they might have a higher output like a electric pump.At that point you would use a regulator.Theres 2 types, a "dead head" which does not return fuel,heat up the fuel and puts stress on the pump or a return style that returns the unused fuel to the tank, so a "cool" supply of fuel is always pumped forward.
Iskwezm is offline
Tivo304
08-28-2023 12:19 PM
StalkerGT
09-25-2015 02:41 PM
raleigh05GTO
09-04-2015 07:09 AM
5.0 kevo
09-03-2015 06:24 PM
SYNY5TER
09-02-2015 01:35 AM
Quick Reply: fuel line questions
