water pump bolt positions - 68 / 289 w/AC
Old 05-28-2012, 05:14 PM
David E
David E's Avatar
Default water pump bolt positions - 68 / 289 w/AC
So I knocked over my tray with the water pump bolts laid out in position.
Anyone got a diagram of where the bolts go and do any go into a water jacket?
Tks.
289 w PS / AC
David E is offline
Old 05-28-2012, 06:48 PM
Starfury
Starfury's Avatar
There are four long bolts on either side of the pump, one each above and below the ports on the back of the pump. They go through the timing cover and into the block. The lowers definitely go into the water jackets, although I can't recall if the uppers do or not. Use Permatex #2 on the threads of anything going into the water jackets.
One of the four bolts should be longer than the others. That one goes on the upper left (as you're looking at the front of the motor) and also holds the alternator bracket on.
Starfury is offline
maestro1024
09-21-2015 02:40 PM
TfcCDR
09-14-2015 12:08 PM
jaiidutch
09-14-2015 10:29 AM
ryland
09-13-2015 12:35 PM
Quick Reply: water pump bolt positions - 68 / 289 w/AC
