1973 351 cleveland can you ID these valve springs?
Old 08-28-2013, 08:05 AM
Sparkiewalt
Sparkiewalt's Avatar
is there any way to tell what kind of valve I have without pulling the heads???
Sparkiewalt is offline
Old 08-29-2013, 09:16 AM
Sparkiewalt
Ok I have checked out my old cam, turns out it is the exact same one I was going to order.
Competition cam 32-221-3. The springs look and measure the exact same as the ones that are in the kit that comes with the cam. But I checked and I do have the multi groove valves, I assume they are the stock style 2 piece ones that are crapola. I just do not have the money for new valves right now, so I am going to get this cam and try it.
http://www.autozone.com/autozone/par...6_1489%2C58670
What do you think?? The springs installed height meets the manufacturer requirements.
Also does anyone know why my old cam was so worn on 6 lobes?? 6 lobes were badly worn down while the other lobes looked perfect. 1 lobe was almost round it was so worn.
Old 08-29-2013, 08:59 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
someone probably used old lifters with the new cam...also modern oils are missing the zinc although there are some oils out there like ones for diesels that still have the zinc and also some specialty oils
http://www.carcraft.com/howto/ccrp_0...m/viewall.html
rmodel65 is offline
Old 08-29-2013, 09:01 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
from the article
Engine Oils Containing Higher Levels of Zinc Phosphate
BRAND WEIGHT
Castrol Tection Extra 15W-40
Chevron Delo 400 15W-40
Mobil Delvac 1300 15W-40
Shell Rotella T 15W-40
Quaker State Q Racing 0W-5, 15W-50, and 17.5W-35
Joe Gibbs Racing MicroZol 0W-20, 10W-30
rmodel65 is offline
Old 08-29-2013, 11:45 PM
67mustang302
67mustang302's Avatar
I exclusively run Amsoil these days, for various reasons....the above stated being one of them.
67mustang302 is offline
Old 08-30-2013, 09:11 AM
Sparkiewalt
WOW..I never knew that about the zinc. I will definitely go with a high zinc oil from now on in my mustang. I thought that maybe some bad lifters were possibly the cause. Does the low zinc oils cause lifter problems??
Old 08-30-2013, 09:19 AM
Sparkiewalt
thanks for the artical link..that was very informative. You guys have been a real help to me and I appreciate your valuable advice. It has surely saved me some heart ache.
Old 08-30-2013, 10:24 AM
Sparkiewalt
so when I go to do a total rebuild, I need to go back with a roller cam and a nice set of roller rockers. I have an extra motor, I will build it so I can keep on driving the car.
Old 08-30-2013, 12:19 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
you dont have to go back roller although it is a nice upgrade...just proper break in and id personally use an oil with zinc in t if you go back with the flat tappet
rmodel65 is offline
Old 08-30-2013, 04:09 PM
Sparkiewalt
I will surely use a high zinc oil and break in additive.
GimpyHSHS
19
12-19-2023 01:12 PM
mustangheaven
01-03-2016 11:20 AM
mustangheaven
10-07-2015 10:23 AM
mungodrums
09-28-2015 10:54 PM
Quick Reply: 1973 351 cleveland can you ID these valve springs?
