Starting issues
Old 02-02-2014, 03:04 PM
404ninja
404ninja's Avatar
Default Starting issues
I recently put in a new Voltage regulator and starter thinking either one of these were the culprit for starting issues. After poking at a few things the car still won't turn over.
The Alternator, starter solenoid and ignition coil are also less than two months old. Any thoughts?
404ninja is offline
Old 02-02-2014, 04:48 PM
creaky
creaky's Avatar
You say "wont' turn over", do you mean that the starter cranks the engine but the engine does not start?
creaky is offline
Old 02-02-2014, 05:26 PM
404ninja
404ninja's Avatar
No, the crank won't even turn. When I go to start it it does nothing besides turn on all the lights.
404ninja is offline
Old 02-02-2014, 09:27 PM
creaky
creaky's Avatar
Hold the key in start position, have an assistant using a test lamp check for current at the starter relay connection to the starter. If there is current, there is a problem at the starter, maybe bad solenoid. If no current, check the red/blue wire on the relay for current, again with the key in start position. If there is current, the relay is not functional. If no current, there is a break in the red/blue wire or a fault at the ignition switch or possibly the neutral switch if one is fitted.
creaky is offline
Old 02-02-2014, 10:58 PM
Iskwezm
Iskwezm's Avatar
Make sure you have good grounds on the solenoid and the engine to body ground.
Iskwezm is offline
Old 02-02-2014, 10:59 PM
67mustang302
67mustang302's Avatar
How old is the battery?
67mustang302 is offline
Old 02-03-2014, 05:37 AM
creaky
creaky's Avatar
Good call. Good idea to use a multimeter and check battery voltage and voltage going to the starter with the key in the start position.
creaky is offline
Old 02-03-2014, 11:46 AM
404ninja
404ninja's Avatar
I replaced the battery when I got the car in early December. I replaced the ground wires at the same time as I did the battery because the old ones were not looking good.
Would dead fuses cause something like this? I know I probably should have looked at them sooner but getting at them requires to have a contortionist on hand or removing the driver seat.
404ninja is offline
djbigskrilla
09-20-2022 01:04 AM
mstahoo
SVT Forums
08-19-2021 09:15 PM
drfister
05-03-2018 10:38 PM
5.0 kevo
09-03-2015 06:24 PM
1st 4 eyed fox
08-24-2015 06:56 PM
Quick Reply: Starting issues
