'68 overheating problem
Like previously stated, pull out the thermostat and make sure that it's working and that it's installed correctly.
I switched to twin electric fans and a huge Be Cool radiator. It was pricey, it's not stock looking and mine is a daily driver. If yours is a weekend cruiser, a once a week driver and you want to keep a stock look, then go with the stock fan set up...and get that fan shroud in place. Also, you could be missing a spacer that goes in-between the fan and the water pump pulley. You want the fan as close to the radiator as possible. You'll need longer bolts too. If you can, post us a pic.
James
James
Foghorn Leghorn
Location: I reside in a near constant state of amazment.
I drive in Florida during the summers with a factory brass 4 core, no shroud and a FoMoCo 7 blade flex fan out of an LTD and it never gets above 190 even in traffic.
mungodrums
09-29-2015 09:18 PM
stangin1996gt
09-21-2015 11:01 AM
yourmom6990
09-14-2015 10:52 PM
