Shelby Tail Light Upgrade
Hi,
I have a 68 coupe that i am thinking of getting the Shelby tail lights and the fiberglass screw in tail light panel. I wanted to see if anyone else has done the modification and if you are happy with it. I have seen some mixed info on the fiberglass panel and getting it to fit right. The plan would be to install it and then get the car painted so it all looks together. Has anyone done this and where did you get yours from if you were happy with it.
Thanks,
Tim
Thanks,
Tim
there are a lot of different vendors and methods for doing this. I'd use the search function on this forum and search for Shelby tail lights or Shelby tail panel. Read through all the threads it returns.There are so many vendors/installs that it's too general a question as is.
Tony D'Branda has all your needs and are top notch.
http://www.cobranda.com/19shpa3.html
They are the Shelby specialists.
A little FYI, ALL fg parts will need to be worked to fit no matter who the seller or vendor, even the parts used by Shelby BITD fit pretty bad.
Lynn
Lynn
M3hunter
09-05-2015 03:42 PM
