how long does paint take - 6 mos!
Old 10-20-2014, 12:47 PM
groho
groho's Avatar
Default how long does paint take - 6 mos!
been awhile since I actually sat down and gave an update. This is what I started with some years ago, as you can see the rear quarter was toast. A lot of time and work and this is what I have as of last week. The interior is being painted as we speak and should have her back in the garage any day. Now its a matter of putting her back together, wiring, interior, glass, etc. I'm a one man operation, so nothings gonna happen fast.
Attached Thumbnails how long does paint take - 6 mos!-mustangoriginal.jpg   how long does paint take - 6 mos!-reartrunk.jpg   how long does paint take - 6 mos!-mustang-unpainted.jpg   how long does paint take - 6 mos!-mustang-painted.jpeg
groho is offline
Old 10-20-2014, 12:52 PM
groho
groho's Avatar
and here is the interior stuff and the motor. The door panels and rear seat are being made to match the Cerullo seats as we speak. Its finally coming together after too many years. Thank you folks for all you input and help getting me to this point. Next comes Maier Racing components, and some good shocks, tires and wheels.
Attached Thumbnails how long does paint take - 6 mos!-imag1042.jpg   how long does paint take - 6 mos!-c5zz65239423p-w.jpg   how long does paint take - 6 mos!-imag0985.jpg
groho is offline
Old 10-20-2014, 11:20 PM
67mustang302
67mustang302's Avatar
Use the shocks from Maier.
67mustang302 is offline
Old 10-21-2014, 04:48 AM
barnett468
barnett468's Avatar
in case you aren't pretty familiar with suspension, it is incredibly easy to get your car way too stiff with springs and shocks. if you need help with these things we can help.
keep in mind that if you ask maier for suggestions, he is the second fastest autocross racer in the us, so his suggestions might be on the stiff side for mere mortals.
barnett468 is offline
Old 10-21-2014, 06:38 PM
67mustang302
Actually, his setup that he recommends for the street and track isn't really that stiff, and rides extremely well. Mainly it's the shocks, but he told me a while back they they still only use the 600lb "street" coils and sport valved shocks on the track car, no need to run stiffer.
My 67 has better ride quality than one of the guys I used to work with who had a 2007 Shelby Mustang GT. Hell, my parents CR-V is rougher over bumps and holes than my Mustang is, though it is an SUV/crossover.
The shocks really can't be understated, they use the acceleration sensitive regressive valving from Bilstein, so the shock is stiff under low motion when cornering hard to give control; but is very responsive to rapid wheel motion that's typical from bumps/holes. I've eaten some insane potholes on the highway at 70 (we have terrible roads around here) and you barely feel it. They have a tremendous amount of control under any road conditions.
They're using a newer shock on their coilover setup they have now, from JRI iirc. I think JRI also set up the valving on the Bilsteins as well, and it's run by a former top Penske designer. If you're changing coils, arms and shocks I'd go that route.
You'd think they'd be stiff, set up for performance, but they're really quite amazing in both performance and ride quality. Though, he does have some recommendations for the rear suspension to get good motion and avoid binding. Poly bushing on the front spring eye with their springs, lets the front part of the spring function like a nice stiff control arm with limited flex and twist, then use factory rear shackles with factory rubber bushings. That way you get location precision for the rear wheels by letting the front of the spring work like a control arm, but the rear part of the spring with softer shackles is free to move around and twist all it likes, and also absorbs a lot of impact force. My rear actually has a really good amount of articulation, keeps the tires planted and rides well. That way you can avoid binding in the rear.
I wouldn't run their 700lb springs with track valving though, unless you have a really heavy car that's track only.
Old 10-22-2014, 07:27 AM
barnett468
barnett468's Avatar
thanks, good info.
yeah progressive and multi stage damping has been around for a long time. i actually worked a lot with it back in the 80's with kyb and works performance and did telemetry tests on the vehicles as well as on an mts machine. lots of fun.
i run 480 front springs and around 135 rears. guess i'm getting old, lol.
Old 10-27-2014, 12:55 PM
groho
groho's Avatar
the mustang was delivered on Friday...looks awesome! The seats and interior paint match perfect. Now comes "assembly required"... here's she is. yes, the cowl hood is all steel. tried to match the cowl off a 2010 mustang, I think I succeeded.
Attached Thumbnails how long does paint take - 6 mos!-resize-new-paint.jpg   how long does paint take - 6 mos!-resize-new-paint-ii.jpg
groho is offline
10-05-2015 07:40 AM
10-01-2015 09:29 AM
Florida Regional Chapter
09-30-2015 08:04 PM
mungodrums
09-28-2015 10:54 PM
GLOCKer
09-28-2015 07:36 AM
Quick Reply: how long does paint take - 6 mos!
