69 351w, dooe heads with mods and z303 cam
Old 01-09-2015, 12:27 PM
  #31
69mach1377
69mach1377's Avatar
First one was OEM and it lasted almost 2k miles. Broke the block too.
2nd one was one piece SS made by Carr and it lasted about 20k miles. Beat up one piston and chamber.
I later figured out that the second block was not drilled correctly for coolant flow, the holes were not big enough like that sketch shows.
So after all that drama, I went to W heads.
69mach1377 is offline
Old 01-09-2015, 07:47 PM
  #32
barnett468
barnett468's Avatar
ok thanks, the stock ones are supposed to explode but i have never heard of Carr . . did you have high spring pressure?
barnett468 is offline
Old 01-11-2015, 10:22 AM
  #33
69mach1377
69mach1377's Avatar
Not really. Carr was in biz in the 90s. No trace of them can be found now.
Old 01-11-2015, 04:16 PM
  #34
barnett468
barnett468's Avatar
i wonder if thats because their valves broke in half.
Old 01-12-2015, 01:11 PM
  #35
69mach1377
69mach1377's Avatar
What do you mean by 'in half'?
Old 01-12-2015, 02:30 PM
  #36
barnett468
barnett468's Avatar
i was just guessing by your comment that it broke in half to beat the piston up as you mentioned . . if it stuck in the guide, the guide was too tight or it had some old gas/tar residue miseed wit the gas.
what exactly did happen to the stainless valve?
Old 01-12-2015, 03:54 PM
  #37
69mach1377
69mach1377's Avatar
it broke not in half, but where the stem blends into the flat portion, at the beginning of the radius
it apparently got real hot while cruising along the highway, no shenanigans were going on, after about 20k miles
uedlose
The Racers Bench
10-01-2015 08:31 PM
NYstang
09-30-2015 09:56 PM
LiquidDrink
09-29-2015 10:06 AM
EASTIDEE123
09-14-2015 03:52 PM
Ryan Fitzpatrick
09-14-2015 02:21 AM
Quick Reply: 69 351w, dooe heads with mods and z303 cam
