Yoke question
You need enough yoke sticking out so that when the suspension compresses and the yoke slides in, the radius of the yoke doesn't bottom on the seal. You have way too much yoke sticking out in that photo, and it will put excessive load on the output shaft bearing in the transmission.
Spicer makes great u-joints, if the shaft has a 1310 end, then just get a 1310-1330 crossover joint. Preferably the Spicer Life series, non greasable and sealed (the Life series have crazy good seals on them). Alternatively you can have the shaft fitted with a 1330 end.
These guys have given you the best answers to your question but let me put it all together for you. With the driveshaft installed and total weight of the car on the tires there should be 1" on the slip yoke showing out of the back. If the driveshaft is to short it can cause extra wear on the bushing inside of the transmission and wear out your slip yoke as well. You will also want to have your driveshaft balanced after it has been shortened/lengthened or even changing slip yokes can create a vibration and led to bearing wear. As for your new yoke you can use a conversion U-Joint to convert it from 1310 to 1330 but the correct way to achieve your goal is to replace the front weld yoke with a 1330 yoke and use a spicier solid 1330 U-Joint.
One more tip, your grease-able 1310 U-Joint is installed backwards. The grease zerk fitting should be installed toward the weld yoke or you will not be able to fit your grease gun onto the zerk for proper greasing
I hope this helps!
I hope this helps!
Thanks guys, it's 1am here and I'm itching to go outside and check something. I didn't know there was a 1310 1330 crossover u joint. That said, I want to measure the total length of the new slip yoke that I have. I think with that installed, it might reduce the 1 1/2 inch gap I have now and not have to take the driveshaft back to lengthen it.
What you guys think?
Is this it ??
http://www.drivetrainamerica.com/p-5...-13101330.aspx
Is this it ??
With the cars weight on all 4 tires, or simulated, the proper driveline length is as follows; slide the slip yoke all the way in until it stops, and then back it out between 3/4" to 1". The rear u-joint should be at the proper location with respect to the pinion yoke. Most likely your drive shaft is not the right length as IIRC, the AOD is longer than a C4?
The travel of the suspension changes with every vehicle, 4 link rear ends will get shorter when lifted, leaf spring cars depend on which side the shackle is located ( front or rear) none of that matters in this case. its all about where the slip yoke sits while the car is at ride height.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
