On modernizing a classic
Old 04-05-2015, 08:06 PM
Starfury
Starfury's Avatar
Mechanical stuff will fail eventually...but often long after an electronic component fails. This is especially true for cheap aftermarket electronics.
These cars are absurdly easy to steal. There's not really a good way around that. Cutoff switches, alarms with ignition cutoffs, almost everything you can do is pretty easy to disable by a knowledgeable car thief. If you're in a theft-prone area you could consider a professionally installed alarm, but it's really no more than a deterrent, hopefully making your car just that much more difficult to steal than the one next to it.
Starfury is offline
Old 04-05-2015, 11:33 PM
barnett468
barnett468's Avatar
Originally Posted by Nurdyguy
What do you guys do for security/theft deterence?
simple, install a hidden toggle switch between the coil ground wire and the ground.
they try to jump power to the coil because that's where people put a switch but they will never figure out the coil is not grounded...ever.
barnett468 is offline
Old 04-06-2015, 07:39 AM
69FB
69FB's Avatar
When I get my car back together I am doing a kill switch, which by the way Barnett468 great idea on the positioning of the switch.
There is nothing you can really do to stop someone from taking your car if they want it. (Rollback and off they go), but there are several deterents. One that I am looking at getting down the road is http://www.ravelco.com/.
After saying all this get good insurance and insure it for the value to replace it with the same style car. That is the only way you will have peace of mind from your car being where you parked it or not.
69FB is offline
Old 04-07-2015, 08:32 AM
Nurdyguy
Nurdyguy's Avatar
Cool idea. I've also thought about a fuel cutoff switch but not having an electric fuel pump makes that more complicated. Plus, they'll still be able to start it but just wont get very far before it dies.
I've looked at the Ravelco as well but the wife doesn't want to spend $500...
Nurdyguy is offline
Old 04-07-2015, 05:10 PM
barnett468
barnett468's Avatar
if you wanted to be extra safe you could mount the switch in the trunk . . they will never ever fin it
you could also mount it under the front seat in the rear of it.
car thieves they do not want to be in your car very long trying to start it.
another simple deterrent is a hood latch pin and cable.
Old 05-05-2015, 02:08 PM
Iskwezm
Iskwezm's Avatar
Do what you want with the car, its YOURS. If you don't plan on selling it, don't worry about the value. Yeas you can add power windows and they will work. Power locks I don't see point for unless its for a keyless entry, which will also work if done right.
Iskwezm is offline
Old 05-07-2015, 10:05 PM
JamesW
Moderator
JamesW's Avatar
Agree 100%. you need to figure out what your goal for the car is. Not what others think is value. Value is determined by you.
JamesW is offline
carid
07-08-2016 09:55 AM
fastbackford351
10-01-2015 12:24 PM
guitarman376
09-30-2015 05:54 PM
fastbackford351
09-12-2015 09:42 AM
Quick Reply: On modernizing a classic
