Removing hurst shift lever from toploader
Old 12-13-2015, 06:43 PM
Silverblade
Silverblade's Avatar
Default Removing hurst shift lever from toploader
Can anyone enlighten me as to the proper steps to remove the hurst shift lever from the toploader? Or does the transmission need to drop down first? I can't seem to get the bolt to the drivers side far enough. Thanks
Silverblade is offline
Old 12-13-2015, 09:03 PM
Silverblade
Ended up dropping trans with it on.
Old 12-18-2015, 09:10 PM
Starfury
Starfury's Avatar
I managed to get mine on with the tranny in the car. Been a couple years, but I don't recall having any problems. Not sure which bolt you're talking about, but there should be enough clearance to remove the three bolts holding the shifter to the trans with the trans still installed.
Starfury is offline
RPM2night
12-25-2015 09:30 AM
MADSCOTSMAN
12-08-2015 11:13 AM
CC_Pony
12-05-2015 08:18 AM
Fermin96
11-29-2015 11:15 PM
donvictorio
11-26-2015 02:58 PM
Quick Reply: Removing hurst shift lever from toploader
