fuel line ideas
Old 04-15-2016, 10:00 AM
bluegt500kr
bluegt500kr's Avatar
Default fuel line ideas
I need suggestions for a fuel line setup. I have a KR and I'm swapping the original Holley for a Quick Fuel carb to make it more dependable. The issue is that the new carb doesn't have the fuel port on the drivers side so that I can use my existing lines. The issue is that the PCV tubing interferes with the manifold(?) on the only dual fuel line kits I've found. Any ideas on a safe system I can put together without calling in an engineer?
Thanks in advance for your ideas!
bluegt500kr is offline
Old 04-15-2016, 10:41 AM
Gun Jam
Moderator
Gun Jam's Avatar
if its a double pumper I suspect that you could take the rear bowl and place it on the front and the front bowl on the rear....This could possibly work.
If its vac 2nd...probably not
Gun Jam is offline
Old 04-15-2016, 12:48 PM
groho
groho's Avatar
You should be able to purchase a complete fuel line kit, pump to carb for under $100, just pay attention to the dual fuel line at the carb, there are two sizes based on carb inlet spacing, 8 21/32" or the wider 9 5/16". The PCV may require a new hose because it probably runs to the rear carb base currently. Holley places the PCV at the pass side bottom, QFT probably does the same.
groho is offline
Old 04-25-2016, 03:59 PM
bluegt500kr
Thank you for the suggestions. I contacted Quick Fuel and they sold me a new front bowl that has the driver side inlet and it allows me to use stock Holley tubing to connect the bowls. They were helpful and I got it in 3 days. Nice, clean stock look and it's amazing how much better the new carb works vs. 38 year-old one.
Drastang
20
04-30-2016 04:03 PM
trackers
03-31-2016 02:29 PM
abrucru@aol.com
03-29-2016 02:49 PM
abrucru@aol.com
03-28-2016 03:15 PM
LukeBizzy
03-26-2016 01:36 AM
Quick Reply: fuel line ideas
