Engine build question (New to this)
Old 04-28-2016, 11:03 AM
john65
john65's Avatar
Default Engine build question (New to this)
I have a bare 302 short block and want to rebuild however after moving several times all other parts were lost and now I don't know where to start, any help would be great.
john65 is offline
Old 04-28-2016, 12:22 PM
jwog666
jwog666's Avatar
https://play.google.com/store/books/...IGtA&gclsrc=ds
here is a good start
jwog666 is offline
Old 04-28-2016, 04:38 PM
barnett468
barnett468's Avatar
Buy the parts you need, then rebuild it.
barnett468 is offline
Old 05-02-2016, 10:18 AM
racer_dave
racer_dave's Avatar
Several of the bigger houses have rebuild kits. that will be the best way for you to go I think. You can get everything from just the gasket set to a full rotating assembly, balanced with all the fasteners. Jegs, Summit both carry Eagle kits and Scat kits. The last full race engine I built I used an Eagle kit and it was spot on. I didn't even have to swap bearings to get my clearances right. After that its heads, intake etc...
Don't go overboard on the HP increase or you'll have to do more work to the chassis/driveline to handle the power.
racer_dave is offline
Old 05-02-2016, 03:34 PM
69mach1377
69mach1377's Avatar
Or just buy a crate engine and be done with it...sell the block for a few bux.
69mach1377 is offline
Old 05-04-2016, 09:58 PM
BKKSW
BKKSW's Avatar
First, measure the bores and see if the block is able to be rebuilt. 289/302 blocks with standard bores are increasingly rare. If it measures okay, take it in for cleaning and magnafluxing to ensure there are no cracks. While there get an estimate for needed work - Cleaning, magnafluxing, boring, align-bore, freeze plugs, if a stroker notching, if making lots of power consider oil passage upgrades, decking, balancing, etc, etc.. consider that estimate against a new block and the needed parts. And consider that cost against a crate engine.
BKKSW is offline
tylersn95
06-08-2016 09:08 AM
65mechanic
04-27-2016 06:49 AM
BigSkoop
04-26-2016 12:49 PM
Mach2
04-13-2016 12:52 PM
Quick Reply: Engine build question (New to this)
