65 six sputtering woes
Old 07-11-2016, 12:04 PM
frankmm78@me.com
frankmm78@me.com's Avatar
Default 65 six sputtering woes
65 Coupe 6 cylinder (200) running woes:
My 65 mustang 6 wants to start and sometimes does but will not keep running, sputters then quits. Was running well until a few weeks ago.
I have repaired or replaced the following:
Replaced the Fuel Pump, New points, Dist cap, Plug wires, Spark plugs
Rebuilt carburetor this past weekend
I will be resetting the timing, and looking to change points to electronic ignition or installing a new distributor....looking for a recommendation on this.
I don't think it's bad gas. Have been running regular non ethanol fuel. Looking to drain tank next and blowing out the lines. Fuel tank is relatively new, 8 yrs old.
This seems to be a common problem from what I have read, just can't figure it out.
Thx in advance for any help.
frankmm78@me.com is offline
Old 07-12-2016, 04:12 PM
guitarman376
guitarman376's Avatar
Have you changed the fuel filter as well?
guitarman376 is offline
Old 07-12-2016, 04:28 PM
Chromeshadow
Chromeshadow's Avatar
Have you done any troubleshooting? Do you know if the compression and vacuum are OK? Have you checked the spark and the fuel? Have you checked the timing with a timing light?
Chromeshadow is offline
Old 07-12-2016, 05:49 PM
frankmm78
frankmm78's Avatar
Will be checking the timing this evening. Have not checked compression...thx
frankmm78 is offline
whosniffedme
05-08-2016 10:35 AM
95droptop
05-19-2003 09:42 PM
kornfan_88
04-17-2003 10:09 PM
dragntoys
03-20-2003 10:43 PM
spike306
03-06-2003 11:45 AM
Quick Reply: 65 six sputtering woes
