exhaust size
#21
RE: exhaust size
ORIGINAL: Soaring
Yeah, but that is unlikely with a stock exhaust manifold. Hell, even with a tuned header, you are still going to get some back pressure unless you run it wide open right out of the head. Old racers opened up their manifolds exhaust systems with a cut-out for years, because it created a better flow, therefore more horsepower. Look at the funny cars. Right out the top from the header.
As far as installing it yourself, I have done 3 cat back systems on four wheel drives with the clamps that were included in the Flowmaster kit.
#22
RE: exhaust size
ORIGINAL: 6mustang6
Yes, I know now GLen. Do you think i could install the exhaust myself?
#23
RE: exhaust size
Yeah, if you are going to bolt it together, you can absolutely do it yourself. It's easy, and a lot of fun. The more work you do on your car yourself the more proud of you will be. Just take it very easy when going over speed bumps. When I first got old yeller, it had bolt on exhaust pipes on it, and I hit a speed bump a little hard one day, and it separted the pipes and bent the back one up under the car.
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
10-05-2015 06:07 PM
09-03-2015 07:14 PM
kawiguy827
09-01-2015 07:09 PM
