Gas Gauge 68
Gas Gauge 68
Please be gentle with me, this is my first time: I am a novice new vintage Mustang owner andfound out the hard way that my gas gauge registers a 1/4 tank when I'm out of gas. Also, when I fill the tank the gauge stops between 3/4 and 7/8 full. I took the sending unit out to see if the float needed adjustment. It all looks o.k. Also, with the harness disconnected the gauge did drop further, but still above "E" (1/8 tank). Could the sending unit be bad or is there some calibration that can be done to the gauge? All suggestions are welcome. I have not tried a new sending unit yet. Any thoughts? Thank you for your time.</P>
</P>
</P>
Gas Gauge 68
BFry:</P>
Thanks for the input. Did your gauge exhibit the same characteristics? Even when I had the wire un-plugged from sending unit the gauge did not go below 1/8 tank. This makesme think it's the gauge (?). I think I will try the sending unit first, did you have any trouble setting the gasket? Any tricks to get it all back together? Regards.</P>
Gas Gauge 68
I didn't check the guage while it was disconnected, sorry. Everything seemed to go fairly smooth, maybe I was lucky. I had a friend of mine give me a hand who had done this before, so that helped.</P>
GOOD LUCK!!</P>
jwog666
12-27-2021 08:09 PM
Matt's 95 Stang
10-05-2015 07:16 AM
