Battery Light
RE: Battery Light
welcome!
It sounds like your voltage regulator and possibly your alternator is shot.
The regulator is in the alternator... I had to replace mine and upgraded to a 3g in the process.
I don't know what kind of alt. 00 mustangs have though
RE: Battery Light
Check the battery voltage with the engine off. Then start the car and check it again. have someone rev the engine a few timesand see if the voltage drops. Its an easy way to check the charging system. 8 years is a long time for a battery, but it could be something else. I,ll check my 99 sometime and will have good data to usein future posts.
RE: Battery Light
99% of the time that light comes on it means the alternator is toast. well then again there are times that the belt could be loose, and not that the alternator is defective. if it's not on tight enough the car will run off the battery, and trigger that light because it isn't functioning. i don't even know if the light would come on if the battery was done. everytime in every vehicle i've owned or driven when the light came on it always involved replacing the alternator. i can think of 6 different vehicles i drove while the light was on. 4 of my own.
logan409
09-26-2015 07:43 PM
09-25-2015 09:06 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
