Sponsored by:
Sponsored by: DashLynx
Bad gas?
Old 12-25-2007, 09:56 PM
Mass Driver
Mass Driver's Avatar
Default Bad gas?
My car has been sitting for a3-4 months with the same tank of gas in it. I started it up and during warmup it was smoking alot (white smoke). Could this be due to gas that has been sitting in the tank for too long? What else could it be? Thanks
Chris
Mass Driver is offline
Old 12-26-2007, 06:12 AM
corvetteguy
corvetteguy's Avatar
Default RE: Bad gas?
My guess is it is not the gas, it
is the moisture being heated in the
exhaust. I have gas 4 years old in my stored cars and
it will start, as long as I mix in some premium.
corvetteguy is offline
Old 12-26-2007, 08:48 AM
Jfsram
Jfsram's Avatar
Warm exhaust gases plus cold exhaust pipes equals white smoke.
Take it for a drive. At least 10 minutes and report back with results.
In VERY cold weather the pipes never heat up and even with a fully warmed up engine you can have white smoke.
Jfsram is offline
Old 12-26-2007, 09:04 AM
Mass Driver
yeah it is pretty cold here. below freezing atleast
Old 12-27-2007, 12:10 AM
kenv
kenv's Avatar
ORIGINAL: Jfsram
+1^^^---Any other time you get white smoke, you have a coolant leak/head gasket problem
kenv is offline
Old 12-27-2007, 08:12 AM
onesickstang01
onesickstang01's Avatar
yes coolant leak is very possible, i had the same problem on my 73 stang and it was a very simple fix
onesickstang01 is offline
4cylinderplus2
10-09-2020 07:45 PM
Sixer4Life
10-12-2015 04:26 AM
Dathan
10-05-2015 05:52 AM
UrS4
09-30-2015 10:13 AM
GLOCKer
09-28-2015 07:36 AM
Quick Reply: Bad gas?
