compression test
compression test
i plan to do a compression test tomorrow sense i have the day off but had a couple of questions because its been a while since the last time i did it. anyways, do i stick a spark plug in the wire coming off the coil and let the coil spark on the block? also, wont cranking the motor so much without spark flood the motor?
thanks
thanks
RE: compression test
remove all plugs first,from all cylinders,disable the fuel,either disconnect the fuel inertia switch,or have someone hold the throttle wide open while cranking.5-6 seconds is good enough,just count the needle movements or pulses.do all the cylinders the same amount of crank time to ensure equal readings on your gauge,hope this helps,good luck with your outcome.
its a 92 but nothing is stock. before i invest in a dyno tune and e-cam, i want to check my compression. im getting the cam anyways, but it feel better knowing i dont have to change the head gasket when i do the cam
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
GT350 S550 Tech
09-29-2015 03:29 PM
