pro shifted tko
RE: pro shifted tko
Basicly a pro shifted trans has the syncos face modified and eliminates the blocker rings. If you have ever seen a syncro they have a bunch of small teeth, when the trans is proshifted they eliminate all but four of these teeth, it pretty much elimates the syncro. The up side here is very fast upshifts at WOT, but this comes at the exspence of being able to downshift and up shift at part throttle with out rev matching. There are a few ways that proshifting is done but they all do the same thing. You will still need to use the clutch, but the trans will shift much faster.
