Sponsored by:
Sponsored by: DashLynx
Fans cooling proper direction???
Old 07-28-2005, 04:22 AM
uwti
uwti's Avatar
Default Fans cooling proper direction???
Having some trouble trying to keep my 428 cool, I had twin 2500 cfm pusher fans mounted and connected as if pullers (mistakenly). Obviously this was not doing the job. Bought a new single 2900 cfm puller fan, mounted the pushers on the outside and the puller on the inside. Ran the car and found that it got hot even faster???? WTF!
Ok now I am going through the docs again, found that I may have my wires reversed on the puller, but it seemed to be pulling air in??
The main question is why did it run even hotter? I think I know the answer but I want to hear it from someone else!
Tomorrow I try reversing the wires, and run it again.
uwti is offline
Old 07-28-2005, 05:46 AM
03GTType
03GTType's Avatar
Default RE: Fans cooling proper direction???
I think its like you said fans pulling air the wrong way..
03GTType is offline
Old 07-28-2005, 11:58 AM
JD1969
Pro. B.S. caller outer
JD1969's Avatar
You want the fan mounted on the engine side of the radiatior and wired as a puller, this is the most effective way for a fan to function. Now in your post you never said what diameter fan (fans) you have, a shroud will help out a ton, because without one the fan only moves air over a small portion of the radiatior. The reason it may not have cooled as well with all those fans is that the airflow through the radiator was reduced. Hope this helps
JD1969 is offline
Old 07-28-2005, 01:03 PM
uwti
uwti's Avatar
I am running 2 12" pushers from the front. and a 16" puller from inside, no shroud on the puller
uwti is offline
Old 07-28-2005, 02:44 PM
JD1969
JD1969's Avatar
ORIGINAL: uwti
With no type of shroud you only are using the 16 inchs of your radiator that is covered by the fan. What I did on my last car that had cooling issues was to measure the radiator and then I hit the junkyards in search of a shroud that would work. I have also seen guys who work in the HVAC field fab up some really nice pieces.
JD1969 is offline
Old 07-28-2005, 06:23 PM
LightSmith
LightSmith's Avatar
Has anyone tried Evans NPG+ Coolant?
LightSmith is offline
BOB ROME
07-26-2023 01:54 PM
jwog666
12-27-2021 08:09 PM
PaulH2
20
01-31-2016 09:48 AM
09-25-2015 06:42 PM
09-25-2015 09:06 AM
Quick Reply: Fans cooling proper direction???
