Running wires though firewall?
I have a 2000 V6 and am wondering where is the easiest and best place to run wires through the firewall into the engine compartment. What do you guys do for subs, fogs, and other accessories? Any accurate or detailed descriptions would be awesome. Even pics if you can. Thanx in advance. I looked for about 10 minutes, and didn't have a clue?
RE: Running wires though firewall?
ORIGINAL: Y2K TRIBUTE MUSTANG
What pedal is the rubber boot in front of in a manual? or is it pretty obvious? Any other suggestions?
i run my wires through the rubber boot used for my steering shaft. just crawl under the dash and take a look.
Uuuummmm.............. ya,you could, but its not that hard to look and see anyways!It might have something right on the outside such as wires that could get hit by the drill or whatever you make the hole with.I wouldn't ever drill a hole without looking.The steering shaft boot does work but its kinda in the middle of no were if ya know what I mean.when the wires run there is looks sloppy IMO.The easiest thing to do is drill a hole right under the brake fluid reservoir and put a grommet in it.
cardsrus1
19
09-15-2015 08:37 AM
