Sponsored by:
Sponsored by: DashLynx
LS1 in a Mustang wagon
Old 12-17-2010, 02:52 PM
alcwkat
alcwkat's Avatar
Default LS1 in a Mustang wagon
I finally found a well-preserved '83 Marquis wagon (LTD) w/ V6. Unfortunately the trans is a 3 speed, not AOD. Since I'll be replacing both motor & tranny it makes sense to go w/ LS1+4L65E, probably from a GTO. Questions:
Anyone make motor mounts, or will fab be required? Would it be easier to use a tubular Kframe w/ Chev mounts? I'll keep stock manifolds.
And any tips on flaring the front fenders for wider tires/wheels? Eastwood roller didn't do much.
Hopefully flaming will be minimal since it's not a real Pony, just a Fox!
alcwkat is offline
Old 12-20-2010, 09:50 PM
JIM5.0
JIM5.0's Avatar
I don't know if it can be done, well, not without some fabrication of parts.
For example, you may have to mod your driveshaft to mount to the LS1's tranny.
The engine mounts? I doubt the LS1 will mount directly, and I doubt that there are aftermarket mounts to adapt it. So more fab work unfortunately. Same for the K-member.
Sorry to rain on your parade; the LS1 is a totally different beast.
JIM5.0 is offline
Old 12-21-2010, 08:51 PM
alcwkat
alcwkat's Avatar
GM yoke will be easy compared to the rest of it. Fitting an instrument cluster will be lots of fun. Can't find a chromoly, so I'll probably go with the AJE parts as per singe's post:
http://www.ls1tech.com/forums/small-...or-mounts.html
Yeah, they're very different - state of the art pushrod.
alcwkat is offline
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
chain
08-17-2015 08:52 AM
daytooday
08-11-2015 09:22 AM
Quick Reply: LS1 in a Mustang wagon
